Vertiviper
So, once my KM arrives i'll be going through everything to make sure the factory didn't miss anything.
What fluids/checks will I need?
well theres really only 2 to start with
differential, and shock, check those out make sure they are well supplied,
the only other one and you will get lot of differences of opinions on this is the 2 cycle oils, everyone has the one they like, so thats something you will need to look at and decide what works best for you,and whats available to you look in your area hardware or auto parts stores and see whats offered.
alot of brands from amsoil, lucas, redmax, castrol,caster oil's etc. the list can go on,
Is synthetic widely used on these? Is there a better spark plug option as well that most folks use?
Yes please do use synthetic IMO it is better the spark plug NGK will give you great service
can be, don't rush it and if you have a mini torch get it out, some of the bolts might say "they don't want to come out" and strip out ,may need a bit of persuation, but over all wont take that long takes me about an hour to pull the diff, longer if the bolts act up
2mm , 2.5mm , 3mm, 4mm, 5mm those should cover all of the screws in,on ,and around the buggy, might even be 1-2 6mm if i remember?
