Need advice for sandrail cage
and where i can find the light pod? i don't have it either though
and smaller than stock one...
im not 100% on what you mean bye that but i think something like theys would look sweet an its plug an play pritty much just have to find a way mount them cause you don't have a roof yet but once u do its as simple as drilling 2 holes an a 12v batt thats it hears a like on the light bar ... http://www.mcssl.com/store/rc-lighthouse/rc-light-bars/pro-line-light-bar-with-working-led-lights an maybe headlights an tal lights http://www.mcssl.com/store/rc-lighth'ouse/rc-light-bars/pro-line-light-bar-with-working-led-lights an they come with "pods" so all you have to do once the aluminum sheet are mounted is trill 2 tall light holes an head light holes stick the wire an pod in the hole an turn on the nut an your set :) pleas let me know if you need any more info thanks
new link http://www.mcssl.com/store/rc-lighthouse/2w2r-10mm
I mean the pod that the same as stock 5b lights (black plastic), hope you know what I mean.
how about this light...
I forgot, but actually I saw somewhere that is for 5b
EDIT:
found it, it seems to be still prototype though
http://www.hpibajaforum.com/forum/showpost.php?p=1491956&postcount=242
i like the one with the spare tire on the back idk if its just me but still looks like its missing something on the front end
Can you tell me what is missing on the front end?:confused:
How about if I add front panel...
I'm about making a spare wheel adaptor to attach it on the back
adding a front section would make it look more complete imo, also if there would be some kind of way u could add some vents on the front hood , maybe some nerf bars as well just a thougt .. still looks good
Vents??do you mean like a scoop on the hood?
If you look closely actually i have made the nerf bars, little bit hard to see on those pics though
yeah looks to be metalllic blue with a little peral in it , not sure on how u would make the vents just throughing u ideas
just crossed in my mind, maybe i could cut lines on a small aluminum sheet and bend them a bit
yeah try that should work with a lil time and some needle nose pliers try it on some scrap to see how it looks i think it would look cool to leave the vent section stainless if u r going to paint it just so they will stand out
