painting 2nd hand shell ?
chris18
Surrey UK
guys
just bought a used Leopard shell not really liking the colour but it was a good price
can i paint the outside ? what paint would i use ?
chris
That would be my first call to try and remove the paint. have done it to 3 1/10 and 1/12 scale bodies but can take some time if it is thick paint. I also found the cheaper dot 4 worked better than the more expensive stuff. in fact one type barely did anything whereas the cheaper workrd like stripper. It does leave the shell misty and blotchy in places. there are a few dedicated products available to do this but are expensive and slow. If you give up the bodies can be painted on the outside, they will scratch easier but of course can more easily be repainted after a light sanding down. here are two examples
DSCF3678.webp matt black auto paint (halfords)all over
and black ploycarbonate on outside
Justin
Great job, but damn, that's a lot of work!
I'm too impatient for that!!
I can understand if it's a shell you cannot find anymore, and certainly with 1/5 shell prices.
Smaller scales, I would probably just get a new shell to be honest!!
Al.
right
just a little update guys on my 2nd hand shell
after all i decided it was way to much hassel getting the paint off the inside so decided to paint the outside instead so started prep the shell funny thing it after putting some degreaser on the shell to clean.. parts of the paint started to flake but i still went with the outside
1st thing i had to make the shell fit as i bought this 2nd hand! back was easy but front was a little tricky it being 2nd hand and from non Fg owner..anyway i made something up to fit and it works well :)
i used some fine sand paper to rub down washed and dryed sprayed a thin coat of plastic primer and waited to dry after i used some good old fashion car spray in matt black and painted the end result is pretty good just need to see how long it will last now lol
pics below with show you a kind of process i took
regards
Chris:cup-1:
oh and ordered a few stickers will update soon
your right that was fuggly. I know some people that use the truck bed-liner aerosol spray on the outside in situations like this. It's a little more durable then regular lexan paint.
Almost nothing worst in the RC world to the environment then removing paint from a body. Not to mention your health. Just replace the dang thing.
