Read what descriptions mine?
This description
[FONT=Times New Roman, Times, serif]IT'S HERE!!! THE ALL NEW UPGRADED 30.5cc T1000!!
[FONT=Times New Roman, Times, serif]One of the finest radio-control vehicles ever produced has just been upgraded; the T1000 Desert Racing Truck. This 1:5 scale, ready-to-run off-roader is manufactured with extreme attention-to-detail by King Motor Sport and is offered by Heat Hobby. This huge, fast Truck has it all; upgraded chassis, a newly-designed 3 Channel 2.4Ghz radio, & now with a redesigned 30.5cc engine you will have no problem leaving the competition in the dust! [/FONT][FONT=Times New Roman, Times, serif][/FONT]
King Motor T1000 Desert Racing Truck
"Heat Hobby EX Edition"
1:5 Scale / RC / Ready-to-Run / 30.5cc / Gas Powered
[/FONT]
Features:[/FONT]
[FONT=Times New Roman, Times, serif]• Huge, 1:5 scale (39 inches long) & super fast (55+ MPH)!
• Everything's included (Just add gas, oil, & 8-AA controller batteries)
• Upgraded & Redesigned 30.5cc 2-cycle piston-valve, air-cooled, recoil-start engine
• Easy to fuel - uses 2-cycle pre-mix, 25 parts gas to 1 part oil
• Large fuel tank for long runs
• Adjustable carburetor with choke and prime button
• Extra-long, double-wishbone suspension: 7 3/8"-front & 8 1/4"-rear
• Upgraded Fully-adjustable, 6mm oil-filled, heavy-duty VVC shocks to dampen any terrain
• Tough, 3-piece nylon rims w/ new, stronger gray bead-locks & replaceable tires
• Stiff, aluminum chassis
• Stops quickly with the vented rear disc brake system
• Upgraded3Channel 2.4Ghz LCD Computerized radio system with built in fail safe
• Upgraded Hi-torque metal gears (33 kg/cm), water-resistant steering servo
• Upgraded Hi-torque metal gears (15 kg/cm), water-resistant throttle servo
• Upgraded Automatic, long-life clutch, with improved 8,000 RPM clutch spring
• Upgraded Chrome tuned pipe gains you 1HP
• Upgraded Aluminum differential with metal gears(differential housing is composite)
• Upgraded Newly designed chrome wheels with one inch wheel extenders
• Sealed electronics box for use on wet days
• Upgraded Increased-density body kit
• Precision manufactured for years of use and customization
• Speedy shipping from our USA warehouse![/FONT]
Specifications:[/FONT]
[FONT=Times New Roman, Times, serif]Brand:
Model:
Scale:
[/FONT][FONT=Times New Roman, Times, serif]Drive:
Max Speed:[/FONT][FONT=Times New Roman, Times, serif]
[/FONT][FONT=Times New Roman, Times, serif]Vehicle size:[/FONT][FONT=Times New Roman, Times, serif]
[/FONT][FONT=Times New Roman, Times, serif]Vehicle weight:[/FONT][FONT=Times New Roman, Times, serif]
[/FONT][FONT=Times New Roman, Times, serif]Wheelbase:[/FONT][FONT=Times New Roman, Times, serif]
[/FONT][FONT=Times New Roman, Times, serif]Tire Diameter:[/FONT][FONT=Times New Roman, Times, serif]
[/FONT][FONT=Times New Roman, Times, serif]Shipping box: [/FONT][FONT=Times New Roman, Times, serif]
[/FONT][FONT=Times New Roman, Times, serif]Shipping weight:[/FONT]
[FONT=Times New Roman, Times, serif]King Motor Sport
T1000 Desert Truck - Heat Hobby Edition
[/FONT][FONT=Times New Roman, Times, serif]1:5
2 wheel
55+ MPH
39" x 17.5" x 13.5"
35 lbs.
22.5"
7"
41" x 20" x 15"
39 lbs.[/FONT][FONT=Times New Roman, Times, serif][/FONT]
[FONT=Times New Roman, Times, serif]Includes:[/FONT][FONT=Times New Roman, Times, serif]Ready-to-run, completely assembled truck
White color body
Sticker set
3 Channel 2.4ghz LCD radio controller & receiver
Spare parts bag, with many of the most commonly needed parts
Mixing bottle
8 piece tool kit
Battery charger (110v plug)
Receiver battery pack
Spare air-filter
Improved owner's manual / schematics
Whip antenna
PLEASE NOTE: DUE TO BOX SIZE, THE NEW LARGER WHEELS ARE NOT INSTALLED ON THE TRUCK BUT ARE INCLUDED AND EASILY INSTALL WITH ONE NUT [/FONT]
