need help
Disco
Active Member
salisbury
my baja wont start ive tried adjusting the needles nothing ive tried fitting the old standard km carb nothing ive checked the spark plug nothing wrong with it i put a couple of drops of fuel in the engine it fires up then dies any ideas
Make sure u dnt have a clog in the lines n check if the carb cycles the fuel through it also check the filter in the carb under the primer bulb
2
Also check to make sure you did not put the lines back on backwards. If it runs when you put fuel in the top its a line or tune issue. Did you put the needles back in the base setting.
2
theres no clogs in the lines ive not checked the filter i try that. how do i check if the carb cycles fuel through sorry if its a stupid question but its my first petrol rc
ive got the black on top and the clear one on the bottom ive tried putting needles back to base settings
Ine way would b to take a line off n try to prime it on both lines
2
took the carb apart and cleaned the filter the lines are on correct still wont start i don't know what else to check
I only have one other idea thats to take the carb n take the screw from bottom off n che,k that filter screen
2
2
yeah i checked that mate when you said to check the one under the primer bulb. Its annoying cos it was running really well and i don't really want to buy another carb as ive not had it that long and it wasnt cheap
Ya thats wat i just had to do cause mine went out just today
2
