fuel tank vapor ventilation
mcd fuel tank
which item did you buy.....is it just a vent or an anti surge;)
a picture would help
K....
I purchased the item for largescalerc the package says fuel tank vapor ventilation FT. I believe its the anti surge. Has no instructions?:w00t:
i'm using one of those T fittings in a gas return line for my twin so gas sits in it all the time, seems to be holding up fine, for just a vent tube there will be no problem. they use nitrile o rings that are petroleum resistant, nylon bodies and ss teeth
28 euro for a vent kit you can make yourself for less than $6, now that is robbery
as usual with any MCD after part mooman very expensive and can be made up
by yourself for 1/3 the price :D
speedfit fittings
PNEUMATICS FITTINGS
Side Loads
Fittings should not be subject to excessive side loads and should not be
used as support brackets. Tubing and fitting should be adequately
supported to prevent excessive side loads.
Material Specifications
The fittings are made up of three components:
Bodies
Bodies are produced in an acetal copolymer engineering plastic, especially
suitable for pneumatics and corrosion free applications. Selected bodies
and body parts are brass.
‘O’ rings
Are Nitrile rubber
Collets
Are produced in acetal copolymer with stainless steel teeth.
Chemicals
For use with chemicals or other potentially aggressive liquids, please refer
to our Customer Services Department.
Super Speedfit
fittings are not recommended for use with explosive gases,
petroleum spirits, and other fuels or for central heating heating systems.
K....
