Silent_Chaos
Sup guys,
Got my XB 10 months ago, try and Made it hard basher (I hope so)
Upgrade parts installed on Car:
-Aluminum C-hubs
-Al. front and rear bearing holders
-Al. cage
-Al. shock towers
-Al. gear housing
-Al. Steering rocker
-Universal Dogbones
-Green type Boca Bearings
-CPI Rear pipe (very loud)
-Triple protection Air Filter
-MT Resi Shocks with 40Wt shock oil
-Wt-998 carb
-4x Rear Trenchers
-Savox SV 0236 MG HV steering servo
-HITEC HV 7954 Throttle servo
-M11X Sanwa Transmitter with Killer RC kill switch
-DGI Steering links
-DGI rear upper links
-4x FLM hardened CVDs
-7075RC front and rear Diff housing
-8000 rpm HPI clutch house and spring
-Lightened Flywheel
-Double mesh Fuel Filter, Fuel lines, snappy tank vent
-Killer RC 7.4 V 7200 Mah battery with splitter (lessens the load on the M11x Receiver)
-DDM Receiver Signal Filter (for better response)
-Killer RC Super Stainless steel pull start (already installed)
-7075RC Black anodized Non Flex Chassis
The only missing Upgrades are the Front and Rear Lower Suspension Arms. since the car is tough now, the plastic arms are wobbling since they're being the weak spot.
gona install them from 7075RC when they are available
overall money spend on this (including shipping +customs) around 5500$
I live in Lebanon and customs here suck
Performance of car is good. But I should have gotten a Losi 5ive instead, with that money spent on it, it would have been freakingly rigged
-Aluminum C-hubs
-Al. cage
-Al. shock towers
-Al. gear housing
-Universal Dogbones
-Wt-998 carb
-4x Rear Trenchers
-DGI Steering links
-Lightened Flywheel
