Painting body lines?
celm
once question how do you or what would you do to make body lines ? ill post a pic for example, I like how the lines break up the car body panels so it doesn't look like 1 big shell
well you can do it the way you suggested without the trim tape the trim tape will not stay on the inside on the lexan unless you put it backwards then it will be hard to peel off and probably leave tape residue.
On the pic s you posted that was done on the outside with trim tape if you enlarge the pic more you can see the tail lights which is a sticker they applied on the outside and went around the tail light sticker with trim tape if you look very closely you can see where the heated the trim tape to curve around the tail lights. That is not 100% paint.
