Losi 5ive-t won't start
Losi boy
New Member
Haven't ran it in a few months. Put in new plug and fresh fuel. Can't get it to crank?
Any thoughts?
Haha it would be cool if you could fit a storm trooper action figure in there..... Gonna need more info. Won't crank? You mean the rope feels stuck? or do you mean won't start up?
What carb. do you have on it ?
Does it have spark ?
Is the fuel new ?
Answer these & the questions above, and I bet we can help you figure it out.
Yes it won't start up. Fresh gas and plug. Only change is fuel tubes
Is the fuel new ?
WT990 carb
New fuel yes
How can I tell if it has spark?
I put a new plug in.
Thanks for helping guys.
WT990 carb
New fuel yes
Get spark plug out of motor put it in cap have wife hold it against metal fin of head and touch here tongue against tip
Then jurk pull start rope then start saying I'm sorry I'm sorry as fast as you can if she screams it's firing
If not you found your problem
If she screams you have still found your problem just not the one you were looking for [emoji87]
I fixed it guys thanks for the help.I just pulled the spark plug and put a little fuel in. It's as loud as thunder.
Any thoughts?
Your Carburetor needs to be replace, it is better to replace it for $50.00 than dis-assemble and rebuild. Check out rebuilding Carburetors on you tube and you will see how hard it is to rebuild. I know because I had to replace mine. Just my option.
