NEW LOOK!!
Thanks guys, there is still a TON of work left for me to do so please be patient while I work frantically to get the everything worked out.
If you run into any issues please use this thread to let me know as well! :)
Is anyone else having trouble using this forum on Tapatalk? I keep getting messages that this forum isn't compatible with it.
I have to log in each time - doesn't keep me logged in once I shutdown the computer.
Not difficult, agreed, but more inconvenient than before.
Al.
Al,
I think I found the issue. It seems the forum was allowing both http://largescaleforums.com and http://www.largescaleforums.com to be used. While to you and I it looks like the same address, to computers they are reading the www. as another site and was messing up the login cookies.
Now only the www. version of the site should be working and everyone's login cookies should be good to go. You may need to log out and back in just to make sure but once you do that everything should work from there on out. Let me know if that's not the case.
Tapatalk is an addon that still needs to be installed. With the new software tapatalk is not necessarily required anymore as LSF now displays very nicely across all platforms, phones included. That said there are a ton of things that I'm still working on, tapatalk in the future is one of them. Hang tight. ;)
