madmanandrewk
- 9
However, you say you didn't replace anything that wasn't broken, how did you break the engine?
I kind of forgot about the head and pipe when I wrote that. Lol I replaced them before ever driving the car. I think if I could go back I would just stay with 1/10 scale, I really didn't want to spend this kind of money on a toy.
I have that much in mine not including the cost of the DBXL haha. I haven't really "broken" anything on it. I put the spark plug through the roof this weekend so I had to get a new plug wire. I could use a center diff cover seeing as it cracked around 2 of the mounting holes the first time I removed it and put it back on. I'm also running some serious torque with a bartolone ported g320 and his pipe but I check the shafts and pins before eveyone run.
Me too. That was actually the first thing I ever broke, before I ever even started the car when I was rebuilding the motor. I've just been putting off replacing it since it's technically functional.
How long you been running the G320 engine? Some have had issues with running this much power which puts me off slightly....You been ok?
I added the DDM 29cc bore up kit to my DBXL and lost the whole rear drive line . ( this was the original U shaped one) when I ordered a replacement I got the one that is more like a ball socket and lost the pins twice. I then bought a pin at the local hardware (4x20mm) inserted it then wrapped .005 shim stock around it and used heat shrink to hold it in place then wrapped electrical tape around that. I have run it twice so far and it has held together.
maybe the chassis braces also , I still have the stock plastic ones.
