If you want to put in the investment, get the rb innovations cooling intake manifold becuase its way better here's the link oh also I'd get a new air filter cuz stock one looks cheap but not absolutely necessary http://www.davesmotors.com/RB-Innov...Diaphragm-Filter-for-Zenoah-G320-Engines.htmlAnything else I need to order before I place another order?![]()
Which one 30.5cc?I bought me another gas RC, Rovan buggy. Might have to order another G320, maybe G340.![]()
Yup it's basically what it is but It also has a diaphragm filter, the 27cc motor is slloooowww so it's worth a different motor ?It looks like a big heat sink block and it's $50 vs $4.. I bought the cheapest one, 27.5 cc. Figured i might have to replace the cheap Chinese motor.
Agreed did you ask redcat or whoever you got it from for a refund or a parcial refund? You shouldI'll go w stock for now. Just want to get it going. It's no fun when I spent $800 and the damn motor didn't even make it through break-in cycles.
Hopefully! If ya can post a video here of it running?G320 looks promising. Well built and big intake port. With DDM Dominator, should give it more power.
Probably not too small (considering) but probably not too good, the 1107 (the one the g320 comes with) is pretty good.Wonder if Rampage stock carb is too small for it.
Does it have a choke?V3 Rampage. I think it has 1107. Don't know much about gas RC, learning as I go.![]()
Most of the time they have a cheap knock off that sucks to tune, my Baja had one and they sucked, went for the 813 (won't work well with the g320), before replaceing id test it and if it sucks, get the 990 or 1107Yes.
Same. Good luck with the new motorOk. Have heard about Rampage carbs being hard to tune.
