- Thread starter
- #901
Well poop, nothing ever goes to plan, the issue now is that the viscous washer (never had it in before so i think that's what was creating excess play) won't allow the gear pin to slide into the drive cup. Its like it's too thick? Should I try sanding it with 220 grit sandpaper? I'm really at a loss right now as to what's going on. I have to go somewhere now so I don't have time to screw with it till later tonight
Where is the pic?Well poop, nothing ever goes to plan, the issue now is that the viscous washer (never had it in before so i think that's what was creating excess play) won't allow the gear pin to slide into the drive cup. Its like it's too thick? Should I try sanding it with 220 grit sandpaper? I'm really at a loss right now as to what's going on. I have to go somewhere now so I don't have time to screw with it till later tonight
Yeah man chill ???He said he had to go out doug... give him a chance to get back home
Are you using the Rovan diff case. It doesn't work with the HPI internals . I found that out the hard way when I was doing my diff this past winter . Or was it the Rovan internals that don't fit in the HPI diff case. It was a cluster f__k to to say the least . I had to wait a week because I had to order more parts when I was putting my diff together.Well poop, nothing ever goes to plan, the issue now is that the viscous washer (never had it in before so i think that's what was creating excess play) won't allow the gear pin to slide into the drive cup. Its like it's too thick? Should I try sanding it with 220 grit sandpaper? I'm really at a loss right now as to what's going on. I have to go somewhere now so I don't have time to screw with it till later tonight
WOOOOOWWWWWW ?????Sounds like shell be nice and tight for her first time?
Just how we like em????Sounds like shell be nice and tight for her first time?
Nope, $30. Not bad.What dose the madmax go for $60? 80?
Even better?? so you got that covered??Nope, $30. Not bad.
Yip ? slightly annoying that I didn't get to finish the tranny today but rather have that than a half assed set up ? need to get measuring my screw sizes, I hate doing it cuz it's boring as hell but needs to get done. I'm just thinking aloud LolEven better?? so you hot that covered??
