you need a handful of .250 side links from master link kits for small roller chain, debur the eye holes very very burr free. pick your color of BYC crossbow string on a spool for making strings. now what you are trying to do is make limit cables for the shocks. string through 12 times through the link eyes to make a cable that has 6 strands on each side of link eyes, Now this is where these cables are better as you can wind them up to make shorter or unwind to let out, Just like tuning the cables on your compound bow, leave the string bundles a little longer than need and tie the bundle string with string makers knot. serve the ends near the eyes to about 3/8-1/2 inch away from the link eyes just do end serve near eyelets and no center serve, keep serving very tite. . now twist the eyes up till the cable is where you want it and install just like Killer cables. this setup is nice as you can adjust to what you like and the string bundle does not chew your rig up like the steel cables do and weigh next to nothing
