- Maryland, USA ??
After break-in now(but not by much)and past their 90 day warranty but I did send them an email. We shall see.
Iv done break in on my rc motors?? but not on any garden gear?
That's good to know??I have have never did a break in on my rcmax engines. He says just run it like you stole it from the get go.
I think they'd be fine honestly. Most the standards we're told to do are out of a abundance of caution most likely. At the end of the day, a Zen is a motor built for construction and landscape equipment. I highly doubt you will find much difference at all. Not sure how fast my demo saw spins, but its way faster than my string trimmer. The thing screams. Ill see what carb is on it today if I can. Not only did I not break it in, it chokes on concrete dust any time I use it. Runs like a champ.I always do a heat cycle or 2 then check everything is still tight before I let it have it.
Try putting a 1107 carb on and holding it wide open, see how long a weed whacker engine lasts at 18k plus rpm?
We're only talking the engine yes? When it comes to the engine, with the only caveat being stock zens, I would beg to differ. No way husqvarna is gonna completely retool to make a few thousand rc engines. I'd bet good money there is very little difference. Now the crazy ones you rich folks use I wont speak on. They're clearly different.Maybe it coz we spend 2k + building or rigs and the wackers 250-300 .......not the same??
I have one i ran over with bobcat that i can strip down, but its a stihl so unsure who makes the engine. Only zen engine I have is in demo saw, and its significantly bigger than what we use. Unsure what it is but I believe its a k750.I mean I am surprised no one has done this before.Take two of the motors apart and compare them side by side.It should be easy enough to do and I am guessing you can find a few weed whacker motors for cheap.
It is, everyone has a different method. Which is fine ? im just Gunna follow my engine builders method as know no better lolI agree with Sean on rings seating best under load.I usually run my built motors on cars under load with no boost and much smaller injectors for a few miles to seat the rings and then swap out the injectors and introduce boost gradually.I am not the one tuning the car a buddy does that for me but you get many different opinions on seating rings it's just like the which oil is best question?
