Minnesota RC
Fellas, I am not getting fuel to the cylinder head and instead of being sucked in, the fuel is being pushed out from the carburetor. I am at a lost for why this is happening.
Yep. The fuel lines are in the correct locations. All gaskets were tight.Fuel lines on the right way?
Inlet to the bottom - outlet to the top.
Yes, the head was leaking and a gasket needed to be replaced.
Made my own gasket from a gasket sheet.
Cy 29 and cy29rc are likely the same thing . And if they are not the parts will still transfer just fine.Instead of getting a new engine, and knowing that there is something wrong with the cylinder head/crank case, could I just buy a long block and transfer parts from the old to the new? If its a CY 29 CC is that the same as a CY29RC?
Or should I get a brand new engine? Could I get a larger CC long block?
All your stuff will transfer, the front bolt on the shroud ain't Gunna line up thoCY29 is a two bolt, I'd need a four bolt which would be the G290RC![]()
No, the 320 is different. You need different clutch housing, shroud, and intake manifold (i think). Rest is the same as far as I knowBut regardless, the Zenoah 31.8 long block would work fine, including fly wheel, clutch housing, etc?
Buy a zen Shroud then, they are like 10 bucksI'd want everything to line up though.
