Minnesota RC
After putting the Zenoah 31.8 on the Rovan, shes a beast and moves fast. Quicker than the Losi with the 23T pinion. Its so fast however that even 3/8 throttle, the tires spin - even with knobby tires. Its in grass/gravel/dirt but its spins nonetheless. How could I put the traction back on to the rear tires without it spinning. I'm thinking about losing the springs as much as possible (putting the adjustment nut to the top) on all four shocks.
Because of the Rovan engine, I increased the pinion and spur gear set-up to bring the rovan to a higher speed setting, but with the newer engine - it has to much acceleration. I though about changing the gearing but then I'd have to buy new gears so what else could I do to reduce the donuts and get it back to chasing. And yes, i let up on the throttle as i make my turns and when I'm past the point of tangent I accelerate again only to spin in circles.
