- Southern California
Let it fly and have fun. Watch the Rovan look alike carbs. Make sure it's a true 1107 cause a lot of the clone carbs have tuning issues. I wonder what is the hp rating on it. I wonder if the stock Zen 32 would be close to it.Crucial it was $179 with free shipping. Comes with walbro w1107 carb
my money says that's a Rovan 36cc. It's ok but it's no power house. I have one sitting in a box that I replaced with a OBR34CC Reed case.Anyone running this? I’m thinking of installing it on the kraken vekta
@Bryan K. If the piston craps out, it will be a good learning experience on tearing down and rebuilding??
Yes. The Vekta uses the baja/standard clutch housing.thanks for the info @Polar_Bus
so when i bought this engine, i had a choice either for losifivet or "baja". do they mean rovan hpi baja
i chose it for losi fivet because i was planing on building one for my son
plans changed its going in the kraken vekta lse . so my question is, what is the difference? i'm thinking it's the clutch
do i need to get a different clutch for a baja to fit it in the kraken?
What he said.btw ,these rovan motors are not real cy. They are knock offs and just says cy. Real cys are really reliable , and they don't even make up to a 36That's a CY engine that's used in many of the Rovan's . I own a Rovan and the same 36 cc engine. I'll be totally honest speaking from my in-depth experience of this engine and i'll say it's a total cheap POS out of the box in stock form. It will run, it can be tuned to run great and get the intended job done good, BUT be very wary of random air leaks. These CY engines are slapped together so poorly from the factory but you won't notice this unless you completely tear the engine down and examine all the internal parts. Keep your air filter clean, always favor a slightly rich tune, and the stock engine will run good. search under my user name and you will find some good reading info on my experiences with the CY engine.
