- Nj
Got any pics of what it looks like on the hex?
hes posted pic?Got any pics of what it looks like on the hex?
?Ok I got a bit of an issue. Apparently these are DBXL rims and apparently the DBXL has wider threads. Any ideas?
ahh...good point ?Talking about the backside...seeing if its seated all the way @evssv
this is what i thought aswell ?I use my dbxl wheels and 5ive wheels interchangeably. Theres no off set difference or rim center thickness difference that I can tell
plan B now then....?Yeah theyvare seated all the way back. If I look inside the thread hole I can see the rim thickness is about double then the baja.
he'll need sum longer threaded hubs now then?...my plan B...?Hm. Can't say getting extensions will help your case here
maybe for a diff model yeah...?.long as hub shaft sizes r the same...job done?@evssv do longer threaded hubs even exist?
Says they are for losi however I was able to put losi rims on my baja before. http://www.largescalerc.com/163079-white5imianwheelforlosi5ive-tbysilverbackrc.aspxGot the part number for those rims? They might be for another 5th scale that has longer hubs
I'm gonna try and get these milled out if I can't find longer threaded hubs. Shame cus they are really nice.Part number checks out for 5t. Seems strange that they don't fit. I see it says +3mm offset but that won't cause your issue. You say the hub is seated all the way in the hex so im not sure
I could opt for 3d printed metal ones.I'd mill down your hexes before the rims...get a cheap pair of knock off hexes to cut up
