Exceed Hannibal 32cc engine and suspension upgrades
Smoothk9
Active Member
So I’m wondering if it’s possible to lift the 1/5 scale Hannibal, to get more ground clearance and engine upgrades for the 32cc please if you got links and actual parts that can work let me know thanks guys ???....
I’m a total noob but in love with my Hannibal and my kraton 6s
Not sure what motor is in that but I got a ESP race ported top end ( DDM $120) and put it on a Rovan bottom end and it ROCKS for a cheap setup IMO, along with a DDM Dominator Pipe for $89 blemished , taller tires or tighten the shock spring nuts more this will lift it some.
Looks like its based off that 4x4 rovan baja. I doubt there will be a lot of options, as far ad lifting it. Depends in what you can cross the parts over to. Measure the uncompressed shock length, the inner diameter of the spring to start. Already looks like you have plenty big tires on it, doubt you'll be able to go much bigger without gearing it down, and again don't know if you can because of the 4x4 set up. Decent pictures of the suspension set up would be helpful as well.
how long r ur shoxs?diameter? whats ur max arm drop?maybe then we can offer up matches ?
Not sure what motor is in that but I got a ESP race ported top end ( DDM $120) and put it on a Rovan bottom end and it ROCKS for a cheap setup IMO, along with a DDM Dominator Pipe for $89 or tighten the shock spring nuts more this will lift it some.
Is it this?
Kinda looking like baja style shocks, but tbh, looks like your arms don't have a lot of room to go down farther before they hit the chassis. I'd your just looking for stiffer springs, your going to have to pop a front and rear spring off the shock to confirm my thoughts that they should be compatible with baja shocks, of I'm right you have a few options for heavier springs.
Engine wise. A tuned pipe, or ported head kit will get you more powe. Idk how or what that engine is supposed to stack up against, as I found no information on it, but I would go out on a limb and say it's a rovan or such, so it should be compatable with zen parts. Tuned pipe would be your best bang for buck, but it will make it quite a bit more noisy.
One more question, what are the biggest mud tires available to put on bug Bertha .
I took off part of my exhaust, and was wondering if it’s better flow or I need to have everything on it.
Need more Information to answer that. What's the rim size on your truck? Does it have the sts 24mm hex for the wheel drive? And you realize you'll have to re gear your truck so you don't loose all your power from going with bigger tires. As well as most likely get better steering servos as well. I think the losi mtxl tires are about the biggest you could go, but don't know if they would fit your wheels.
Your not getting the full benefit of a 2 stroke engine with out a proper pipe.
Think that's the pig tail exhaust, I'm pretty sure you'll find a bunch of hpi baja parts will fit your buggie.
You need to know your wheel specs to see if they fit. If they are a lot bigger you will have to re gear your truck or your engine wont be able to turn them.
Stop editing your old posts as well. No need to go back, just make a new post.
I ordered this for it for now.
