- Thread starter
- #421
I’m not worry about the engine, the owner of the Vekta i talking aboutHe's running the 80 weight don't matter
He'll be right around 55lbs give or take a few..basing weight off my KV5TT with every alloy add on and I'm still pulling the front wheels off the ground![]()
it was on the day i meet up with him and broke the cup of my 5B in 2 min run and end up order the MCDOoohhh!!!..wait till she actually kicks in
Must have missed that. Ill look into it.They should work. @dougstar made some for his Baja
Funny you should mention that. I was about to ask if that was an issue.When I ripped last time, the stone dust and gravel whaled my rear trailing arms and diff housing, are you guys experiencing this, the kv5tt won't accept the rear crud deflectors in stock form but now the stance is much wider I could probably fit a set.
