Baja Shock fluid, fork oil / engine oil/ synthetic / mineral
Steve2021
Active Member
Hi, I have a Baja mainly for bashing around in the garden / farm fields and want to freshen up the shock oil...
I don't know what thr previous owner was using but I see alot of talk about people using fork oil and some even use engine oil..
Also I have seen synthetic oils and mineral oils, which do you use for the baja shocks??
I have some 30w Briggs and Stratton ride on mower oil would that work in the baja shocks?
Also any idea on a oil weight setup for general offroad/ field bashing? Rear shocks have 16 holes and front shocks have 2 holes
Thanks
Silicon oil is what I use. Fork oil is so thin that it leaks out faster and heats up more than silicon. Stock the shocks come 3 hole piston in fronts and 12 hole for the rears. Right now I'm using 45wt for fronts and 25wt for rear. Start with something similar and work from there. My setup is really soft which is what you'll want to an extent. If you do jumps maybe go 5-10wt heavier. Good luck 👍
Thanks
I use 45wt rc shock oil all around . I wouldn't use anything else other then the rc stuff, could damage the seals. And the proper shock oil is so cheap why screw around
You have a Baja?
Silicone rc shock fluid
But I thought the 1/5th Bajas were Not designed for Silicone Shock oil as it damages the seals? The standard stuff is petroleum oil based, not silicone...??
I read that it also states on the manual not to use Silicone oils?
Thanks
Hi,
I am in the process of changing out shock oil on my pitbull x 1/5. Basically a hpi 5b baja bolt for bolt. Anyways I was getting ready check check shocks as they were sagging when I saw these were running without oil. That's another matter but I will add oil. I don't find any specific info for my rig but I did come across info that you should never use silicon based oil in 5b baja. Interesting
Hi,
I have reat that before however I've always used silicone oil and never had an issue
Thanks. Difficult to really know which way to go, but the warranty is long gone on this rig so not much too loose I think. Oil is oil in this case. Before I go and buy proper shock oil I just used 2-stroke oil to check for any leaks ( remember I mentioned that the shock were bone dry), and sure enough the bottom seals leaks. I can get a shock service kit but can anybody tell me if I can get a off-the shelf o-rings to seal the bottom shock end?
I used rc shock oil to start w/o reading the instructions...
It worked fine, but the o-rings in the shocks seemed to stick to the shock shafts a little.
I have seen that before, and a little silicone based grease on the seals helped but the issue was still there.
Later i ended up bending my front shock shafts, so it was time to freshen it up.
Then i read that the proper oil is motorcycle fork oil...
Much cheaper than the rc stuff, so i gave it a go.
Shocks are much smoother than they were before, and as a result the rc handles a little bit better.
Use what you want, but motorcycle fork oil works great!
It's all the same, you can get fork oil in Dino or silicon base.
