pulled the trigger
It shouldn’t come with an engine or radio. Appears you already know this.
Servos seem good.
It is a cool machine. A resemblance to the hpi baja.
I ordered everything for a quick release cage. It needs it! @John Parks pointed me in the rite direction for the parts to accomplish it.
the parts you ordered will not work in the vesla.5 they were made for the vekta and the kracken tt truck.
there is no quick release parts available for the vesla.5
Sort of correct, specifically no. But kraken uses almost the same mounts on most there cages. Hell, kraken vekta side cage mounts work on a kraken tsk-b cage. With that said, their quick release mounts work perfect as well, with almost little to no modifications.
On your Taylor 35cc i highly recommend replacing the cheap pull starter with a CY or zenoah and also replace the cheap knock off ignition coil with a zenoah unit.
Kind of disappointing it doesn't have a good coil on it. But I guess if it works, it works
