DBXL 2.0 Centre diff bracket FID
Bulletje76
Who can help me? I have a Center Diff Bracket / Brake assembly by FID. The left brake lever does not return to the neutral position and sticks. The right brake lever does return to neutral. Who knows a solution? Greetings Mark
remove the brake posts and check for burrs and remove burrs if needed fella,
make sure everything is free and smooth, posts, piston/puck etc,
if its still an issue then try swapping the brake posts and see if the problem moves to the opposite brake,
one other thing s fit the top plate / spur cover first and tighten down, make sure both brakes are free of any binding then tighten the chassis bolts, brace bolts etc afterwards,
it doesn't take much to make one or both brakes bind, just take yer time and you will get it sorted (y) ,
i had exactly same issue, i even contacted FID (long story but there CS is a pile of sh!t to put it nicely).
Anyway as Spents says... I used a small file to smooth out the shaft and the small hole at bottom that was it, simple fix but no so simple to figure it out as id tried all sorts & numerous emails to FID who are a complete joke of a company which is why i will NEVER purchase anything FID again.
Feel free to checkout my posts regarding upgrades for the dibby 2.0 & known fixes to fit the parts etc..
https://www.largescaleforums.com/threads/hop-ups-compatibility-list-gas-version.29247/
Thank you for the tips. The brake now works perfectly. Unfortunately, FID is the only one providing this upgrade. Too bad the customer service is so bad.
I like your posts about upgrading!
glad you find them helpful, yeah I too had a good look around at the time but like you say, only FID that offer this part at present as an upgrade! :(
I have the same housing and was blown away by the quality and the bigger brakes, mine didn't bind but my stock assembly did horribly. The braking power on the new FID setup is crazy good.
