FG Marder-Engine Mount
umeshg
LSF Plus Member
PLUS member
North London
I am in the process of installing a new 27cc OBR engine on my FG Marder and have encountered an issue. It appears that the base of the new engine, shown on the right, is a different size compared to my previous one on the left, resulting in a compatibility problem with the engine mount.
I am also sending pictures of the top part of the engine -blue is the old one on the left with the sticker OBR
Could you please confirm if there are different sizes of engine mounts available. Any suggestions or guidance you could provide would be greatly appreciated.
Many Thanks
hi mate thats some big fan cover as far as i know there is nowt for this
i encountered simalar issuses with a tayor 35 you just have to make your own
bracket to suite your small engine mount you may have issues other side on large
to u may have to get dremel out to engine and mount i did
mate have looked again u may have bigger issue the fan case may hit
your rear lower arm fixing point quite alot try a dry fit with just large mount and see
you may have to cut that middle fixing point on cluch side off to fit large mount
