Good to hear you got the pico kill switch hooked up....you will learn to love that...
you can also use it when you make speed pass for tuning ..hit the kill switch..then look at the spark plug....you want to see light black to light brown in color......Slawhammer
Hey, sorry about the late reply. Had to get some stuff taken care of.
Got the Pico switch in and my original DX3 programmed. This thing is great.
I pull the 3rd channel switch towards me, engine dies. I kill the radio, engine dies. I forgot to try disconnecting the RX batt, but I have no doubt that will work also.
Now to find some time to tune this bad boy for max performance.
What did your radio settings end up being for the 3rd channel to work?
Great to hear you got it working for you....
I would say with the DX3 you are using switch A for your kill switch?
I also have a DX3 set to the same settings...for some reason mine does not work...
So that transmitter is used for my nitro truck...........
Oh.. Question..Did you get the steel 19 tooth pinion for the clutch bell yet?
Good to hear your coming along just fine......Slawhammer
Hey bigger I hear ya on the settings...for the Dx3..I had the same settings for channel 3
...I new have the Dx3.0...any more problems I will use the Fatuba 3 PM...
better Tx any way........Slawhammer
