Will Losi drive cups fit the mt diff??
Blackhawk
saw a pic about a losi diff rebuild and the drive cup looked very similar in size and installed in the exact same way.if it fits then there would officially be tougher drive cups.just a thought.
From a pic with no dimensional markings, it would be extremely hard to say that they are closely/almost identical and would fit. The only way is to get one and try.
You're right though. If it does indeed fit, it could be considered an upgrade. However the copper tube mod work great and is way cheaper.
I have a losi 5 and no the diff cup will not fit because it's bigger in diameter where the pin goes thru and doesn't mesh with any other gears from the rampage diffs
