Westsiderkg
- 9
Hi Folks, First off thank you all! I could NEVER have gotten to this point w/o the forum!!! G-man in particular took the time to address allot of my questions. Greatly appreciate your patience! To help others I wanted to pause for a moment and share my winter build list in a consolidated format, especially to assist those newer to 5th scale as I am also relatively new and it’s been a longer than anticipated learning curve for me and I wish I had a clean list to work off from day 1. The idea behind my build was to assemble a Rampage in a manner better suited (IMHO) for a bit more power and reliability w/o getting into an upgraded engine (which I will still do downstream after I blow this one up, hehehe). Anyway, I spent allot of time reading old posts as well as learning a bit solo…along with a few fails, while learning to apply allot of patience. Hopefully this helps others as its hard (IMHO) to start out sometimes without knowing the hobby lingo let alone what fits, what doesn’t, where to get parts, what to avoid, etc. Enjoy!
BASELINE: Redcat Rampage MT V3 32cc
HOP-UPS (UPGRADES) INCLUDE:
MISC:
Again…many thanks to all those who have helped me to this point and in the future as well as I still have much to learn.
- Spektrum S9020 Steering Servo (1) w/ matching Dynamite DBXL Aluminum Servo Arm 15T
- HiTech HS-7954SH High Torque Servo, waterproofed w / plastidip, with matching HiTech 55702 Aluminum Throttle / Brake Servo horn
- Futaba aluminum servo mount 050010B
- Futaba 3PV Telemetry Transmitter Radio with Life 6.6V 1900 mah 2 cell battery pack
- 7.4V LRP 430352 Vtec lipo battery w/JST male to JR Futaba female connector
- 8k clutch kit (HPI) w / piston stop and hpi flywheel pulling tool
- Turtle racing blue aluminum clutch housing case for Losi
- Aluminum gas cap 050032, w/ custom blue aluminum vent tube
- DDM dominator tuned pipe w/ black thermally insulated heat wrap
- DT1 Triple Flow Air filter w / DT1 outerwear’s cover
- DDM tall velocity stack
- Z-RC black aluminum manifold
- NKG CMR7H spark Plug
- RRC-05K motor kill switch
- King Motor Baja HPI axel boot covers w/Peak synthetic grease for cva’s
- Rovan CNC Aluminum Engine, Head Cover, Metal Pawl Pull Start Kit
- Killer RC SSSS Stainless Steel Pull Start Cable
- Redcat 50913 Blue Body
- DDM easy grip body clips – blue
- Aluminum roll cage 050018B
- Aluminum capped wheel nuts 050031
- Aluminum body posts 050015B
- Full Force Metallic Blue Shock Outerwear’s
- Walbro 1107 carburetor (stock)
- Rustoleum Truck Bed Coating on gear cover
MISC:
- Klotz Gas burner Modelube oil
- No Spill 1405 gas can
- SkyRC Imax charging station w / Readytosky 19-1 banana plug
- RCScrewz Rampage MT V3 stainless steel screw kit
- Shoreline Marine Oil mixing bottle
- Blue Loctite for all metal-to-metal componentry
- Mystery Oil and Stabile fuel stabilizer
