Peteolheadz100
- 23
The piece of hose that came for the exhaust coupler on my jetpro pipe seems to be melting from the Heat. What other hoes can I use that can withstand the heat from the header pipe?
I use this hose. One piece lasted a year, I got 3 tanks with the supplied jetpro hoseThe piece of hose that came for the exhaust coupler on my jetpro pipe seems to be melting from the Heat. What other hoes can I use that can withstand the heat from the header pipe?
Awesome man, do hey only sell by by the foot?I use this hose. One piece lasted a year, I got 3 tanks with the supplied jetpro hose
https://www.amazon.com/gp/product/B005B00FAY/ref=oh_aui_detailpage_o04_s01?ie=UTF8&psc=1
Also is 7/8 ID the right size or should it be 1 inch ID?I use this hose. One piece lasted a year, I got 3 tanks with the supplied jetpro hose
Measure yours. On the Dunerunner it fits very snug which I wanted for no slip then used two zip ties. BTW yes it only by the foot and muuuuch cheaper than if you can find it at the parts storeAlso is 7/8 ID the right size or should it be 1 inch ID?
Silencer!!! Surprised there. I don't know the 1" may work too. The 7/8 is what I used on that Dunerunner in the pic. It was real tight so maybe the 1" is the way to go? I don't know mine works just fineI used 1" on mine and it was tight.
Just had to get some 5/8 as well as I blew a hole in the coupling to the silencer.
Waiting for it to arrive.
