Lighter wheels and tires for rampage mtv3
King motor X2 should be available on Amazon. I just got them and they look and fit great. I haven't driven on them yet. Need the 24mm hub adapters and nuts though. Both from King motor too. I'm trying to write up a thread but can't post my "high res" pics lol. Basically they are smaller than stock, almost half the width and about 1lb lighter each!
King Motor X2 Wheels (set of 2) Fits LOSI 5IVE T and Rovan LT 4WD Truck https://www.amazon.com/dp/B017Y70YXE/ref=cm_sw_r_cp_apa_i_dqiICb7MCRFVB
Could anyone tell me what adapters I need to run these wheels, I seen someone have these and they look nice on the MT, can some send me a link to wait adapters to get, 24mm to 17mm
Hey Phill do you know if these come with the nuts to put the wheels on also, I looked at them and read it,not sure if they come with them?
Wait, you want wheels with a 17mm hub? On the rampage MT?
I'm not sure about that, you might want to check the sizes on everything.
If those are 17mm hub wheels they are probably meant for 1/0th scale and probably wouldn't fit the MT correctly...
I didn't notice that.
You need 24mm hubs.
Get four rear baja 5b hex hubs. They fit the Rampage MT and Dunerunner on all four corners. Then you can use any 5th scale wheel and tire you want. I been using Proline Impulse wheels and mx43 badlands tires made for the Xmaxx. All you have to do is drill the center holes out of the wheels a bit to fit over the threads of the 5th scale hex hubs. These are the MX43 20190721_110918.webp
