Sweet! How does it perform?
I had no problem with bolting it up.
I'm planning on doing the same thing actually I was just looking at an O'Neill Brothers engine last evening because I was worried about the width but you've seen the confirm that thank you I do have one question you must have changed the pull start to fit in between the chassis I was thinking about nausea and notching the side of the chassis out to accept the extra wide pull start Let me know what you did sure appreciate it Thanks by the way this is Gregg with 3 g's.
what transmission are you running with that what gearing it looks like the cover is extra wide?I'm planning on doing the same thing actually I was just looking at an O'Neill Brothers engine last evening because I was worried about the width but you've seen the confirm that thank you I do have one question you must have changed the pull start to fit in between the chassis I was thinking about nausea and notching the side of the chassis out to accept the extra wide pull start Let me know what you did sure appreciate it Thanks by the way this is Gregg with 3 g's.
I've got a MT 5th scale RC with a 45 cc motor on it what transmission will I need to hold up with it and it's a 2speed tras on it nowwhat transmission are you running with that what gearing it looks like the cover is extra wide?
