Thanks. I was wondering if the piston that came stock with the engine had some modifications?Piston was fitted as delivered from Akill , Crankshaft was a DDM 30mm stuffed crank for a Zenoah 32 .
How's the engine getting on do you think you made more power from it. Do think the crank and piston was worth putting inHi.
I used a DDM 30mm stuffed crank which I split and used the original rod in.
Piston is an ESP reed piston with port cut outs.
Reeds are carbon, other than a light port and blend , it is standard.
just wondering how does it pick up when running in the car does it pick up revs quick and what's the end torque like. I've got mine been squeezing it in my car on the engine mounts will have to make some minor external mods the strip down and port fingers crossed looks pretty well built thoughHow's the engine getting on do you think you made more power from it. Do think the crank and piston was worth putting in
it will be interesting to see how it goes you'll have to put a video upmore lively than my 30 Degrees North 38 in my Baja 5t , But it aint a Taylor 35 v2.
Not tried it on a decent pipe yet.
KUDOS to the RTE (rooster tail engines) mate, Damo will love this. Rooster 30.5 popped 9.5+ on the Dyno at, at the wheels. All hand machining and a family business of many generations. I'm from Sydney and am about to receive my Animal' 32.... the baddest on offer from 'the rooster's. Cost around $1750; delivered and amazing value considering - the most powerful small block in the world and the most comprehensive after sales service one could hope for. Damo is a great bloke and is incredibly responsive and transparent. You can't get that anywhere and definitely not off 'Fleabay:...I have noticed a few popping up in the U S and hope to see plenty more l.Hope she goes hard for you mate, what were the power output figures, you guy's in America should look hard at Australian company roster tail engins, you could get them cheap with the exchange rate of US dollars to Australia dollars
I'm a Aussie, I have a full mod reed 30.5 & boy does she go hard
Do you know of any cylinder heads that will fit other ,than the stock one?Just be aware that the cylinder stud spacing is different , so you can't use zenoah type cylinders on it.
I made a 30 degree north 38cc cylinder fit my china case i also put in a fmlmf 35cc 3mm crankDo you know of any cylinder heads that will fit other ,than the stock one?
The Flmlf 32cc reed case?I made a 30 degree north 38cc cylinder fit my china case i also put in a fmlmf 35cc 3mm crank
