Rockfootball47
- 4
I’m at a loss and could really use some input. I’ve had my 5T for about 9 months. At the end of last season, with probably 120hrs of driving time, I was having a lot of difficultly starting it and found it had low compression (60psi). Tore it down and found the piston ring groove pin had come out damaging the piston and cylinder. I replaced the cylinder, piston & ring and broke it in following Losi’s break in instructions this spring. Shortly after break in, it stalled suddenly. Checked compression and of course it was low again. Tore it apart and found damage to the piston and ring, with a small chip in the side port inline with the piston damage. I ground the edge at the port making sure it wasn’t raised since this didn’t extend further into the cylinder at all, completely disassembled and cleaned the crankcase, thinking maybe a small piece of debris was leftover from the first failure and somehow got sucked up causing this damage.
I get everything put back together and break it in again. I did notice some oil buildup on the throttle servo. At first I didn’t think much of it assuming it was just overspray from the exhaust. Now I’m wondering if it was coming from the exhaust gasket since I reused the original and it had some chips out of it and likely didn’t have a good seal. I didn’t think much of it and the next day when I was out driving it suddenly died again after twenty minutes. Low and behold low compression again and by far the most cylinder and piston damage I’ve ever seen.
It wasn’t overly hot any of the times it died. The engine always spun freely without binding both before and after it died. What the hell am I overlooking?
