Make sure you have the arrow pointing the exhaust port and the ring gap facing the intake port!!! Make sure the ring is fully seated in the ring groove and not sitting on the "Pin" The pin is there to stop the ring from turning on the piston and hitting a port...
All you can do is pinch the ring in as tight as you can and slide the piston and ring into the head... Take your time and use lots of lube! :lol:
Make sure the gaps in the wristpin circlips (the little retainer clips) are facing straight up or straight down!! If not, the clips will come loose and smoke your cyl...
A little patience and some lube and you'll be good to go!
(No that was not sexual in nature:lol
