FG MT and FG Beetle
Is that for the rear mount? And does the wing attach where the rear MT mounts are? I noticed one beetle Baja body had the front post real close together.
Anyone got a pic with the body off? I think the body I should use id the Baja Beetle Pro??
beetle
Here the picture.
Monsterbeetle pro body posts.
The one you have on the frame above the motor can you use on the front.
Above the motor you need partnr:
FG7154/1 adjustable support 80mm 2 St.
and a plastic body support FG6175 + body support rubber FG6176
Nothing else, than you can mounting a monsterbeetle pro body.
helps me too. seeing how low your front body posts are shows me the beetle won't fit over my pipe without raising it a mile. ok so truck or mcd body hmm
thanks
fg
thanks
I think you needed a another exhaust for your problem.
Here the picture.
What pipe is that? Does it shoot 50 caliber??
