Different clutch housings?
waqr
Sweden
Hi!
I recently bought this clutch housing kit from DDM:
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.4176/.f
When I should install it on My FG Monster I had a hard time to get the large engine mount to fit correctly. It all ended up with me using the old clutch housing instead. When I compare the two clutch housings I noticed that the old one had some material cut off (I hope you understand what I mean) in the lower right corner which allowed the engine mount to fit correctly (see black arrows in below picture:
You could also see it very clearly if you look at this link:
http://www.rc-car-online-shop.de/cg...num=fg_8345&file=&gesamt_zeilen=0Tsuche--8345
Why didn`t the new clutch housing have this material cut off? Which clutch housing should I order if I want the material cut off as shown in above picture? Isn`t the Zenoah clutch housing that I should have for the Zenoah engine?
Confused :blush:
Hi!
Confused :blush:
The one you have bought its a original zenoah clutch housing.
Fg modified this clutch housing for mounting it on a fg car and sell it under the partnumber FG8345
This the one you need, or do the modification on your own.
Hi!
Yes....I think that I will do this material cut off myself in the future since a original clutch house is 6 USD and a modded FG 27 USD :yuk:
