FG Baja RTR
hey guys i have been looking at getting one of the FG baja's. Any recommendations as to were to buy it in the states? Also RTR or kit. I like to build them. But How is the radio and servos with the RTR.. is it crap AM? does it even come with a radio?
the rtr comes with
zenoah 26cc g260rc motor
hitec agressor 3 channel fm radio
hitec hs-805 bb 24kg steering servo
hitec hs-645mg 9.8kg throttle break servo
sub c flat pack rx nimh rechargable battery
8 x aa nimh rechagable batteries for the radio
charge depends on where you buy them from
Sweet thanks for the info.. i really want the competition version but $2300 is a lot to spend on an RC car.. I mean $1300 is a lot too.. I think i spent less on my Helicopter. I have up til now only had electric and Nitro.. Is the gas engine more stable or easier to wrench on.. any advantages to have gas over nitro that you guys might see? Thanks for the info in advance.. Sorry for the noob questions. ;-)
the more you spend now the less you spend later on, i would recomend the competion modle if you can afford it it will save you tripple the money int he long run.
i brought a plastic 2wd mt i have spent over $6000 aud on it, great truck, but its not finshed it will be around $7800 aud when finshed, a competion truck was $4800 aud with hydro 4 wheel disk brakes, i could of saved my self $3000 aud.
gas is easyer to work on and i find its more rewarding.
gas is cheaper then nitro and with gas youll get 30 mins of run time or more.
gas engines are cheaper then top self nitro motors and there is more options for engines.
gas is more stable and easyer to tune
gas is more fun
sounds like gas is the way to go.. I do like the sound of them better than nitro. More of a low growl than a high pitch sequel. Ok so the breaks.. hydro vs cable.. I'm thinking cable less to go wrong.. Any thoughts?
hydros will work better and stop faster, my rear layshaft hydros seam to wearr less then stock mechainical brakes.
you need to install the hydros and bleed them, you bleed them once and get the air bubbles out then your good to go, no more blkeeding if you get it ritgh the first time.
bleeding rc hydros is easy and quick its easyer then bleeding 1:1 scale cars by your self.
can that rtr be fitted with a pipe? looks like it just had a nub on the side?
yes you can fit a pipes on the ready to runs, the competion modles come with pipes, and every upgrade posible, including alloy shock pistons and threaded shock shafts, with is a very good upgrade fior the shocks.
once you buy one you will be hooked, you will want to upgrade it if it needs ity or not, and you will want to add a pipe for more power, this is when the competion modles are good, its cheaper then upgrading a rtr and it comes with all the best stuff already and you get to enjoy the build.
if you buying a 4wd rtr modle or a competion 4wd modle, have alook here these brakes are good, no good for a 2wd modle unless you plan to use front hydros, but for a 4wd modle they are good, as your getting brakes front and rear, it would be good for a basher, but not for a racer imo.
any way hers the link
https://www.largescaleforums.com/showthread.php?t=4967
i have these brakes on my 2wd fg monster truck, they work well and look good, but on a 2wd modle you still need front brakes for the ultimate stopping power but they work better then stock brakes, less wear.
they caliper and the master cylinder are from megitech and the ally gear plate is from tps.
im going to add megitech front hydros to mine and use one master cylinder and see how it goes, if its no good ill use two master cylinders and two brake servos.
cool thanks for the info.. i really want the 4wd comp model but i am really finding it hard to choke down that $2300+ price tag.. even $1400 is hard to swallow.. But man they look sweet.
cable are less than half the price and don't need bleeding ......but get the tuning version as it has alloy side plates
i don't know about in the usa, but fg tunning brakes are more costly then megitech hydros, i would rather save money and buy megitech hydros.
hydros braking is a lot more even, alot stronger, and cause its hydrolic you don't have more braking on one side or brake drag like caples.
is australia fg tunning brakes front or rear $302.75 aud + shipping from from australia
fg tunning brakes front or rear $245 aud + shipping from europe
megitech hydro kits for front or rear $280 aud + shipping from europe
in my situation megitech hydros work out $35 aud more costly then the fg tunning brakes, but i rather have the megitec hydros, even thought you have to bleed them corectly but only once.
well in the US the kits are $200 more for the hydro brakes.. $2500 usd :-(
the extra 200 usd is not a bad price.
the fg competion modles come with Magura 2 front and rear Hydraulic brake sets
to buy the front and rear Magura 2 brake sets by them selfs would cost you $830 usd
Ok i have been on about 5 different forums and i hear people bad mouth the FG 4wd saying its just a Marder is that a bad thing? And the controversy over HPI 5b vs FG 4wd comp is making me crazy.
Darren
www.rcgawker.com
Darren
www.rcgawker.com
Theres nothing wrong with with the FG setup, it's totally up to you on what you want to spend your money on. I have had several different 1/5 scales ranging from HPI, to FG, to MCD and they all suit different purposes. I myself prefer the FG and MCD line up and like the quality of those models. The bottom line is you can't make everybody happy but thats why theres different manufactors to choose from. I say if you feel comfortable with the FG line up and like what they have to offer, then you should go for it. I kinda know what your talking about with the controversy over the 5B and the FG, me personally I don't know how you can compare the two because they are differently designed cars. When people get carried away about what car is better and so forth I just turn my head and say what ever.
I really really want the FG 4wd comp but i am having a hard time pulling the trigger. I have added that car the my shopping cart 3 times now and each time i see that $3000 price tag I think.. I could buy a motorcycle for that, or a jet sky, or a real car. How do you guys manage to buy these cars? I'm not broke by my more fiscally responsible site is screeming at me not to do it.
Darren
www.rcgawker.com
Darren
www.rcgawker.com
then buy the cheaper 2wd frist to see if you even like fg,s. call dddm for a better price
Darren
www.rcgawker.com
Good point about being able to buy lots of other things at that $$. I've been in the hobby for over 20 years and the only thing I regret is that I didn't have as much knowledge before buying over the years. This is why forums are great. You get lots of info making your decision easier, and your wallet a bit lighter. :blink::blink::clown:
I have a HARM BX1 that is 2 wheel drive but I prefer the FG Baja for its 4 wheel drive.
On the BX1, with these slicks on, all it ever wanted to do was spin and it took a while for the tires to warm up and 'hook'. I was ready to get rid of the slicks because they weren't as fun as running the buggy offroad with offroad tires. Then I put them on the FG Baja....totally different....good thing I didn't put them up for sale.
One good thing for me for having the slicks, if I want to go bashing but dread the cleaning from running offroad, I just put these on on the baja and hardly no dirt to clean up. Just a little effort on using a compressor and you're done.
True this and I agree. Reading reviews is nothing compared to actually 'driving' the cars, though. All what a review does for me is for me to salivate profusely. I wish I were rich :(
