2.4Ghz
+1 Zouz That car is an excellent colour!!! Looked good to blast.
J.
thanks dude.
Im still looking for ideas as to where to put reciver box. I currently have one end screwed into the roll bar, and the other supported with a bracket and some good old fashioned tape !! Lol
Just looked at your vid Streetwise,check the mesh on your layshaft/diff ring ! sounds as if your mesh is separating under strain.
Just a thought.
J.
Just a thought.
J.
Yeah i herd that when i played the video back a few times. Think i need new engine mounts, I changed the screws for bigger ones ages ago, but i think now the engine mounts have worn were they come loose under usage etc.
Here's a tip for ya....When using the plastic engine mounts......
Clean the bottom of the chassie pan real good.....now use double back sticky tape
put on the bottm of the engine mounts..set your engine back in place...adjust the gear
mesh......Note: use super glue on the screw threads for plastic.......tighten down
the screws real tight....Let this set upfor 30 minutes.........
Your engine will not move any more......Other thing depends on the chassie pan
you will have chassie flexing....For thatyou need to do a chassie mod.......Slawhammer
Yep that sounds a good tip. Cheers Slaw. that will have to do for now, but will get the alloy mounts at some stage. :-)
Thats what I did and still do for the alloy ones but I use 3M spray adhesive instead of tape. :D
