tmrperformance
F-270 Four Bolt
New Chung Yang F-270 4 Bolt Base Engine Specs
now i know many are going to reply about plating issues and all the common cy issues many have faced in the passed, however i have been working with the US rep for some time now to get things straight so that we can use these engines with out the reliability factor being in the toilet.
the new design is very promising i will provide a link to where u can view pictures of the very impressive 4 bolt 230 as well. no 270 pictures are available as of yet, but the internals do look the same. there are many positive changes on this new cy, among them is better plating which appears to be excellent! the new cy case will accept a zen top end with the simple change from the torx bolts supplied to a set of allen head bolts.
the dome has a flat squish area, the intake side transfers are higher than the opposing transfers, the int and e. ports are 180 degrees of each other, the piston ring locating pin has been centered on the intake side of the piston, the exhaust port has been moved up, the piston skirt has been modified with a larger cut out in the skirts, along with many other high performance geared improvements! the engine is a true 26.9cc, it has a 35mm bore and 28mm stroke, a combo that always makes great power! enjoy the info, soon more to come!
and the link!
http://www.emjayltd.com/reference-2/chung-yang-f-230-disassembly/
27cc, 35mmx28mm Bore & Stroke
Made to compete with the Komatsu/ Zenoahs in that size category.
F 270 New Version Engine:
1) 4-Bolts Crankcase
2) 4-Bolts Cylinder
3) New Piston
4) Powerful Clutch Spring
5) Lighter Clutch Shoes
6) Big Muffler
7) Star shape bolts
F – 270 Specification
Model (2 Cycle Gasoline Engine) F-270
Cooling Type Air Cooled
Displacement cc 27cc
Bore mm 35 x 28mm Stroke
Max. Power PS / rpm Unknown
Max. Torque kg-m Unknown
Min. Fuel Consumption g/PS . H 500 Two Bolt 23 550
Fuel Recommend Pre-mixed (25 Gasoline : 1 Engine Oil)
Oil Recommend FC grade 2 Cycle engine oil
Ignition Type TDI
Carburetor WT-668
Spark Plug Std. NGK: CMR7H
Starter Recoil
In rpm Unknown
Clutch
Stall rpm 10,500 Two Bolt 23 8000
Length mm 158 Two Bolt 23 168
Overall Size Width mm 240 Two Bolt 23 150
Height 199 Two Bolt 23 197
Weight kg. 2.24 Two Bolt 23 2.56
and the link!
2) 4-Bolts Cylinder
3) New Piston
6) Big Muffler
7) Star shape bolts
Ignition Type TDI
Carburetor WT-668
Starter Recoil
In rpm Unknown
Clutch
