i think they go on yea shocks to stop them over exstending???????????????????
im so glad you asked that i didnt have a clue look good though
What are they for?
J.
Yeah,had another look and I think your right. I have said this to Jacko and we suggested the blue bands that wrap parcels.There is a thread on here about this.
J.
well here goes:
The new Suspension Limiting Killer Kables from Killer RC will dramatically prolong the life of your HPI Baja's shocks and drive shafts. Without limiting cables the Baja's suspension will over-extend, causing the shock pistons to bottom out, which damages the piston, seals, and rod end. An over-extending suspension can also cause damage to your drive shaft pins and cups. With Killer Kables you can spend more time running your Baja and less time repairing it. Killer Kables fit on the HPI Baja RTR, SS, and 5T that have FLM, RPM, or stock HPI suspension arms. Killer Kables may also work on other aftermarket arms that have sway bar provisions. Killer Kables are made in the USA from the highest quality, aircraft grade, coated steel cable, and hydraulically crimped stainless steel eyelets.
I made some the other day out of some:
Cable with a bit of solder then wrapped in heat-shrink.
These are on my HPI but if they hold up i'll do some for my FM.![]()
They're basiclly an old charging wire stripped about an inch down either side, bent over and looped together, then soldered, don't forget to put the heat-shrink on first though.
They are not eyelets just a couple of washers.
Not sure how/if they will hold up but its worth 1/2 hour to find out, if not i'll prob get the Killer ones. :cool2:
