RPM Arms with Killer Kables ??
Hyperpete
ON THE COUCH
OK dudes , just a quick one....
Ive just bought some Killer RC "Killer Kables" suspension limiting cables which I'm well pleased with !
But... I'm planning on getting some RPM arms for the front end soon and just wanted to know if anyone is using the Killer Kables with RPM arms, and if they work OK together??
The RPM top arms swoop in a bit more than the stock HPI ones and it looks like they may rub on the Kables ????????????????????
are these mainly for baja range of cars or can i /should i put them on a fg any one else using them on a fg does the fg have the same problem in a big crash ive not had any probs in that area yet but its always around the corner
Nice find BTB , cheers for that !!!:clown:
Looks like the RPM arms are next on the shopping list then !!
Ive heard they are CONSIDERABLY stronger than stock HPI arms.
The Killer Kables are ace ! I wanted them to help protect things when I'm jumping too (I LIKE JUMPING !!! A LOT !!:clown:) It even SOUNDS a lot nicer now if you push the car right down to compress the suspension then pull it up really quick (as happens when jumping), the noise of the shocks topping out harshly is gone ! At last my pistons are safe !!:clown:
i have a set of the Killers and the Hoods straps
so far i have more time on the Hoods, had them longer.
the fronts seem find, bu the rears may of stretched out a bit, though my shocks are fine, and are well setup, so don't slam down. so not sure why they stretched, other than they are getting wet and relaxing the weave.
the Killers have been great. im using them on my FLMs ext arms. had to mod a plade to mount but so far so good.
