Fg body mouts ?? Any ideas thinking tread :)
Large Scale Basher
Reading the Rules!
birmingham
Guys this is the tread where you guys are going to have to use your brains/ ideas :yuk: needs some help dudes I don't have no body mounts on my Fg monster truck cuz it's got a custom build rioll cafe so body mouts have gone so at the moment I canT use my body what Is the best way I can put my body on??
well a monster beetle has mounts that come off the top of the rollbar. you could drill a couple holes through a cross brace and screw a post in from underneath, you could try using a wing mount. you could braze some rod to the roll cage and drill holes for body clips, use side mounts off the side plates....
So here are the pictures you dudes needed so what kind off ideas have you got in mind ? i have sorted the front mount out :) just need to mount the back one some where as you can see its in the picture (the back mount)....
Could try using the same type of plastic you have on there now, but strap it the opposite way on the rear and screw up through the two joints in the rods into two longer body post rods. If that makes sense.:online2long:
