Witch pipe is better on the HPI Baja 5 B SS
quietman
New Member
Hello to my RC family!! I have a question about the Dominator® V2 Pipe... Is it better than the stock pipe that comes with the HPI Baja 5B SS???? (Everything is still stock on the engine)
Thanks
Quietman
Pikesville,MD
Yes mate the rear dom is a good pipe, i have one on mine and the power is amazing!!
defo the best pipe Ive every got for my baja
Andy
I mangled my SS pipe pretty fast. I picked up a Small bore CPI pipe thats as tough as nails. Good power and well protected. I also have a rear dom V1 that has decent power. Compare the two pipes and the cpi has good smooth power from bottom to top. Cpi puts out a little more RPM but the Dom has a little more mid range. I run a Big bore CPI on a 29.5 and a 30.5 with good results also. I made a new lower bracket fo rthe rear Dom that uses two holes in the chassis and a wide plate that welds to the pipe. Helps hold it straight. The stock mout on the rear dom is pretty week IMO. If you can't weld and fabricate buy the CPI. Large Scale RC has them.
