ChuenouXiao
- Thread starter
- #21
Velocity stacks aren't prone to air leaks unless it's the type with the built in choke. A DDM velocity stack will work with that filter.ChuenouXiao said:Guys I'm thinking about something like this http://www.oneillbrothers.com/rc-car/filters/angled-uni-air-filter.html
or
http://www.oneillbrothers.com/rc-car/filters/3-uni-filter.html
Nice and clean... professional looking.... it says that it needs a v stack? Are V stack prone to air leak? Please let me know....
Yep. It'll work. The cut windshield allows fresh air to get into the carb and the body. Gets rid of all that hot air coming off of the engine. Back when I ran nitro's, I used to cut a hole in the windshield. Better cooling.ChuenouXiao said:But Rcdad my XB body is cut on the windshield... completely open... it should work right?
Deluge.... Looks like DDM is out. If I order the stack from OBR, it will work with my engine and the nice filter from OBR too? Is that all I need? Any special gasket?Deluge said:
The tall stack from DDM.... it simply replace my stock plastic filter and foam huh? Should I use the teflon or should I use the gasket that comes with the V stack? I don't think this V stack is angled? I like the 3'' filter but it may not fit unless I mess with my linkage. I don't want to order and then having to ship it back or being force to mod my linkageDeluge said:DDM has this one. It's the same thing, just 1" tall instead of 3/4".DDM Tall RC / CY Velocity Stack (1" height)
Also, you'll want to run an Outerwears or a TGN Redneck with that filter. You keep the XB on pavement most of the time, but better safe than sorry.
DDM carries those filters, as well.
Uni Air Filter (3" height)
Angled Short Stack Uni Air Filter (1.75" height)
Here's the TGN Redneck, in case you want to check it out...
Redneck Prefilter for "Short Stack" Unifilters
Yeah, that was a concern. Looks like the DT1 is a little restrictive. But the spring mod would help, for sure.Ildy666 said:On the dt1 filters.If u cut a small 1inch round spring down to the size of the filter and stick inside it will keep the inside of the filter from closing in on itself.i do it to my filters it works good..
