ChuenouXiao
- Thread starter
- #21
Ordered 8 already. 30 min after my order my package already shipped!!! Dam good service Deluge!
I got the one Deluge recommended... good price and it should be better then stock I believejeeper049687 said:VBX is a fast company, ordered my bearings, i've got them in the truck already and it hasn't even finished posting payment to my bank statement online yet, very quick. check out the lazy susan bearings they have ordered the 9" to make my own workstand, as the cheap one's i've seen are well cheep and the good one's i don't want to pay that much for. i think the 750lb rating might be overkill but it will work great and a good price, not to mention made in USA.
Told ya! VXB is awesome.ChuenouXiao said:Ordered 8 already. 30 min after my order my package already shipped!!! Dam good service Deluge!
You don't notice the performance. The ceramics can run cooler. This is important when you have a size issue like the X-series wheel bearings. Keep in mind you could get a set of 7075RC bearing holders for the price of a full set of ceramics.Deluge said:The ceramics? I didn't see any noticeable performance gains with the ceramics when I ran them.
That is correct. Much of the bearing failure is due to over tightening the wheel nuts. Even just running a set of wheel adapters solves this problem. You can tighten the nut on the adapter to your hearts content and you will not increase latteral load on the bearing.rev9fan1 said:and why the hell doesn't our cars come with bearing spacers!!! thats probably why my bearing broke!!
The ones from Acer fits the Redcat carriers. 7075RC uses a larger bearing for their carriers.rev9fan1 said:because 7075rc says the bearings are this size 22mm x 6mm x 10mm and the ones from acer u showed me are 10x19x5mm
this is the hpi adapters correct?RCDAD said:That is correct. Much of the bearing failure is due to over tightening the wheel nuts. Even just running a set of wheel adapters solves this problem. You can tighten the nut on the adapter to your hearts content and you will not increase latteral load on the bearing.
