1st run on my NEW XT
NCBASHER
Junior Member
Well, I ran about 10mins then I was 2Wheel Drive, appears the front dogbone going to the cup is just spinning i think the grub screw came loose.
I did notice it doesn't appear to have much take off power either.. hopefully that will get better. when i get the 8k clutch installed. I thought about a tune piped but they are just to loud..
The grub screw coming loose on the center drive cups is pretty common. Once you get some red locktite in there you should'nt have that issue again.
Also, a tuned pipe is gonna make a huge improvement. You could slap on a $25 silencer which work really well and do not noticably effect performance.
the problem i see with a pipe none of the ones that are available are really protected and the side pipe looks like a tumor.
btw when is that awesome Belt Drive coming out i read u have :-)
i have the jetpro side pipe for mine and it's no where near as loud as i thought it would be and its a hole lot quieter then the baja ss pipe.
Just about anything is quieter then the HPI SS pipe and gives better performance.
