1st Vid of me bashing near house
I have a question. DOes it really sound like there is no enough torque?
If so might be installing around 6th gears set. I switched from 2nd to 8nt gear set i believe.
So yea
pipeous said:
it does seem a little boggy on bottom, maybe richen the needle a tad. you might also consider a higher stall clutch spring
You mean 8k spring instead of stock 5k?
dan i see you have a jetpro pipe but it just seems to be not enough, so here is a suggestion get you a 28.5cc race ported head kit, and that area your runnin in will become to small,lol...... ok here is part numbers:
headkit: cc255 115.00 dollars
copper gasket .012 thick: ca317 8.00 dollars, but only run this if you have stock 28mm stroke
If I remember correctly 285 is for extra torque right?
I will get full engine maybe for my upcoming dunerunner cause i have 28+2 stroke on my 30.5
Unless I wanna take bottom part of my engine and change stroke, but I don't.
But yea thanks for suggestion, definitely putting 285 in dunerunner or maybe in tt
