2 short videos of my MT running in a parking lot.
It should be!! She'll really come alive when you toss that Jet-Pro on it!! Justt a quick question, what is you gear ratio? Are you running a 48 tooth spur?
that thing is no joke. ive seen plenty of fg vids and even tho they have real good winding mills, that is definatly reall quick for a stocker. cant wait to see it with a pipe
A 2 speed isn't really going to make much of a difference in top end and the low end will be the same (first gear in the 2 speed is the same gear ratio as stock 16/48). Toss that jet pro on it and go up 2 teeth on the clutch/pinion to an 18 and down on the spur 2 teeth to a 46. It will be (a little) less likely to wheelie off the line and have better top end. Great for parking lots. At full throttle it will still pull the front wheels with this gear.
The biggest problem with the 2 speed is getting the gear mesh straight and adjusted properly (It's a lot harder than adjusting the 2 speed on my old Savage) I had one, I hated it and went back to single speed... The other thing is, the 2 speed I bought was plastic, even if I had liked it, I would've had to replace all the gears with steel gears, another $150. I personally believe the 2 speed was made for on road. I think bashing in the dirt with jumps and what not will kill it..
Just my opinion, feel free to disagree :P
Trip..
I might do a 2 speed before I do a pipe, it definitely rips.
A pipe is like getting two speed. At least it was for me.:cool2:
Well I had the chance today to go play in the dirt :) Didn't get vid but did have the upper right rear adjustment rod come out. What tires can I put on this beast to get it to hook up?
Swap your rears around backward it will pull dirt under the tire instead of out and grip off road and on. Make sure the tires with the (M) are on the rear also. :)
Trip..
I have found mine ultra relaible after modding the catch pin and real easy to set up, i run steel clutch pinions and plastic spurs...check out the vid I just posted in the fgbaja section to see how fast a 2 speed can go on dirt:D
