2 Speed
csh9999
Junior Member
Is there a plastic cover that will fit over 2 speed? The stock is to small. Also does anyone know how get Savox 0235 servo to fit in dunerunner? The servo is larger than the stock one.
The Savox is pretty much the same size as a Hitec 5805. I believe the DR and the MT use the same servo mounts, if that's the case you can use the Futaba servo mount from Redcat. You might have to drill two new holes in the chassis though, if they aren't already there.
Link - Aluminum Futaba Servo Mount
