2 x ESC???
Shiny
Dubai, UAE
First off I am not sure if this should be here but did not see Electronics tread, feel free to move if required.
I will use as an example Motor of 200 Amps max & 25 V max.
1)Is it possible to use 2 x 100 Amps ESC to power this motor??
2)If so how do you wire the ESC (Parallel or Serial)?
3)How do you connect the batteries (Parallel or Serial)?
4)How do you connect the ESC’s to the receiver?
Please feel free to cement. The ESC’s will be powering 1 motor (1 x Motor & 2 x ESC). The idea is reducing the load on an ESC maybe cheaper for high Amp applications.
This is just a thought so if you don’t now please don’t trash it.
Thanks in advance to all.
There's a French guy on here who posted some amazing details several months ago, who has a LaargeScale BL with more than one ESC, for some reason.
Take a look through the different posts, you might find it, then contact him - he seems to know quite a lot about these things.
Al.
